An unknown error occurred during solution.
    • Furkanbatesli
      Hello everyone,
      I'm working on static structural analysis of 16 tons bogie axle. I have completed all contacts and mesh processes. But I see ''An unknown error occurred during solution.  Check the Solver Output on the Solution Information object for possible causes.'' type of error.
      There are a lot of entry about this situation. I tried everything but not working. ( core number :2 , turn off distribute solution etc. )
      Could you help me please ?
      I attached solution information text.
      Thank you.
      *** WARNING ***                         CP =      18.875   TIME= 015:06
      Element 1434453 has a radius/thickness ratio of 3.00000021 (minimum
      radius of curvature of 30.0000021 and a maximum thickness of 10 ).
      The number of ERROR and WARNING messages exceeds 200.
      Additional messages suppressed. See ( D:ansys
      proje_ProjectScratchScr9496file.err ) for suppressed messages.
      NUMBER OF WARNING MESSAGES ENCOUNTERED= 213
      NUMBER OF ERROR MESSAGES ENCOUNTERED= 2
      ***** PROBLEM TERMINATED BY INDICATED ERROR(S) OR BY END OF INPUT DATA *****
      You have so many warning messages about element shape that the error is not included in this file.  It is in another file. Please show the actual error message.
    • Furkanbatesli
      Another file ? Where do I find actual error. I don't understand.
    • Furkanbatesli
      ''One or more parts were found to be unmodified so smart updated.'' I always see this warning message. Could this error be due to this warning message ?
      Ignore that message about smart updated, it has nothing to do with your problem.
      In Mechanical, right click on Solution and in the pop-up, you can Open Solver Files Directory.  In that directory is file0.err which has the error in it.
    • Furkanbatesli
      Thanks a lot Mr. Peter.
Viewing 5 reply threads
  • The topic ‘An unknown error occurred during solution.’ is closed to new replies.
