June 12, 2020 at 4:09 am
labolatory
SubscriberI am conducting numerical analysis of two-dimensional convection flow using Ansys Fluent in Ansys student 2020.
Could you show me how to export the data of all the time steps, at a time, to a csv file, please?
At the moment I can only export the data of each time step one by one, or first download all the data as a CFD-Post file and then export it to a csv file, both of which are very time-consuming methods.
June 12, 2020 at 10:10 am
Forum ModeratorHave a look at the text interface and use that to export the data you want. That command can be used in "Execute Commands" to then save data during the simulation. Or, as a journal if you already have all of the data.Â
Use %t to add the time step number to the data file name.Â
June 15, 2020 at 1:28 am
labolatory
Subscriberthank you for your answer.
Excuse me. what is %t
June 15, 2020 at 6:47 am
labolatory
Sorry for the lack of knowledge, what are journal files and %t?
By the way, at present, the analysis result is "FFF-1-00001.dat.gz~FFF-1-03600.dat.gz" for each time step, and 3600 this file already exists for each time step.
June 15, 2020 at 9:42 am
Forum Moderator%t in a Fluent file name will add the time step number, this makes the label unique for each time step. You also need to sort the file name out in Autosave.Â
Journal files are instructions to tell Fluent what to do, usually used to avoid repetitive work.Â
June 15, 2020 at 12:57 pm
labolatory
Is it possible to output the data of each time step to one text file with automatic file saving?
June 15, 2020 at 1:04 pm
Forum ModeratorWith monitors, yes. The data files are saved for each time step.Â
June 15, 2020 at 1:36 pm
labolatory
SubscriberSorry to hear you over and over
Is there a way to export the results of all time steps into one text file instead of each time step?
June 16, 2020 at 3:13 pm
Forum ModeratorIf you mean the data files, then no. If you mean the results of surface or volume monitors then yes. In CFD the data files for a single time step can be many gigabytes, trying to include all of the data into such a file wouldn't be wise.Â
June 19, 2020 at 2:24 am
labolatory
SubscriberThank you very much
- The topic ‘all time steps data export’ is closed to new replies.
6600
1311
