July 2, 2026 at 2:21 am
2210912041_alamirsyah
SubscriberI do simulation airlift reactor using multiphase mixture and steady state any suggetion for looking fluids flow and gas holdup?Â
July 2, 2026 at 8:20 am
Forum ModeratorI find plotting contours of phase to be useful.Â
July 2, 2026 at 4:10 pm
Subscriberi am avoid transient becuase limitation on device and time. My question is can the airlift reactor solve on steady state? I was doing the simulation but it cant convergent, and the water got out to the outlet. But I have already set the outlet Vf_air to 1.
July 2, 2026 at 4:25 pm
Forum ModeratorIt depends on the what flow regime you're in. For a very transient bubbly flow you'll struggle, but a more dispersed system (ie sparger) might just converge. Note, you need to monitor points & flow field as well as residuals as the latter may not drop as per text book.Â
The outlet volume fraction is for the back flow, if it's a pressure boundary anything reaching it will leave the domain.Â
July 2, 2026 at 4:42 pm
SubscriberÂ
My goal in running this simulation is to examine the gas holdup and airflow under laminar flow conditions, given that the spangger inlet has a diameter of 8 cm and a velocity of 0.0249 m/s. Do I need to create a spangger with specific specifications, or is there another way to ensure the simulation is successful? Is there a way to make my simulation work, or do I still have to use a transient analysis? Also, should I split the reactor into two parts and simulate them just half of it to save on computational resources?
July 2, 2026 at 4:51 pm
SubscriberSo i cant prevent water go out from my Airlift reactor? Or i just simulate the water and for the free surface no need?
6790
1331
1147
