TAGGED: 2d-airfoil, drag-coefficient, lift-coefficient
November 17, 2020 at 3:57 pm
MTayyab
SubscriberHi,
i am trying to do a flow over an airfoil simulation at different angles of attack.
I have created the mesh, and for the inlet velocity at different angles of attack i input the correct velocity components my domain is c type domain but when i calculate the lift and drag coefficients i get very small values.
My free stream velocity is 210m/s and at 4 deg angle of attack i get the following values:
cd:
November 17, 2020 at 4:02 pmRob
Forum ModeratorHave a look in help as there's a video going through the NACA airfoil set up. Errors in the lift and drag are often caused by poor mesh, incorrect reference values or Force monitor vectors. nNovember 24, 2020 at 9:13 amFederico2594
SubscriberTry to use the K-W SST model that is better for Airfoil Study.nIs important to keep the correct value of y+ to solve correctly the bundary layer.nRegards,nnFedericonViewing 2 reply threads- The topic ‘Airfoil simulation (NACA 2415)’ is closed to new replies.
