September 11, 2022 at 5:53 pm
manelaero2020
SubscriberHi everybody ;Â
I am simulating airflow in a pipeline with fluent. When I use coupled scheme for velocity-pressure, there is a considerable reverse flow ( order of 90%) at the outlets, and the computation diverges. Still, the problem disappears when I use simplec scheme.Â
Have you an idea why coupled scheme causes this instability? is this scheme not suitable for flow in pipelines?Â
Thank you a lotÂ
September 12, 2022 at 8:39 am
Forum ModeratorWithout seeing the mesh and set up it's difficult to diagnose. I use both PBCS and SIMPLE in most models and haven't observed problems linked to the scheme that couldn't be explained by something else: most models I see are on support so there's usually something wrong.Â
September 12, 2022 at 7:24 pm
manelaero2020
SubscriberThank you Rob.Â
The computation converged with no problem when I used simplec scheme. I have imposed mass flow inlet BC and pressure outlet for outlets. With the coupled scheme, computation converges when I block artificially reverse flow. I don't have mesh actually to show you, sorry. As a solution to the problem, I have refined mesh near outlets and extended outlets but it doesn't work. The mesh is tetrahedral with inflation layers. The initialization is standard, computation is steady, flow is incompressible, and a turbulence model is K-Omega SST . All spatial schemes are second order.Â
September 13, 2022 at 8:31 am
Forum ModeratorI need to see some pictures. Blocking reverse flow isn't usually recommended, and I wouldn't expect much difference between PBCS and SIMPLEC. Did you use the same initialisation values in both cases? Is the flow compressible?Â
September 25, 2022 at 9:18 am
manelaero2020
SubscriberHi @RobÂ
Sorry for the late reply :), I don't have mesh actually to show you some pictures.Â
The flow is incompressible, I have used ' standard initialization' for both cases ( SIMPLEC AND COUPLED schemes)Â
Maybe mesh or geometry is the reason because I have used coupled scheme for other problems of airflow in pipesÂ
and solution has converged ( without preventing reverse flow option)
Have a nice dayÂ
September 26, 2022 at 11:17 am
Forum ModeratorIt could be several reasons, the solver settings tend not to be the cause: it's usually geometry, mesh or bc's. Without more information there's not a lot we can suggest.Â
- The topic ‘airflow in pipe lines : divergence with coupled scheme problem’ is closed to new replies.
