July 26, 2019 at 4:56 pm
marcellszeles
SubscriberHello,
I have a complex model in AIM looking to be solved, and I'm having issues with the out-of-core performance.
Can you kindly let me know which command (and which part to enter it) is used to run the "Distributed Sparse Matrix Solver" in "in-core" mode?
Errors:
/COM,ANSYS RELEASE 2019 R2 Â Â Â Â Â BUILD 19.4 Â Â Â UP20190416 Â Â Â 18:16:19
 *** WARNING ***             CP =    0.422  TIME= 18:16:20
 BCSOPTIO is not a recognized BEGIN command, abbreviation, or macro.   Â
 This command will be ignored.                      Â *** WARNING ***             CP =    37.328  TIME= 18:16:34
 The program chosen initial timestep/load-factor is arbitrary.  It is  Â
 necessary for the user to supply a suitable initial           Â
 timestep/load-factor through the NSUB or DELTIM command for       Â
 convergence and overall efficiency.                   Â *** WARNING ***             CP =   154.500  TIME= 18:17:26
 Component C1 does not exist.  The OUTRES command is ignored.      Â
/COM,ANSYS RELEASE 2019 R2 Â Â Â Â Â BUILD 19.4 Â Â Â UP20190416 Â Â Â 18:18:02Â *** WARNING *** Â Â Â Â Â Â Â Â Â Â Â Â CP = Â Â Â 0.406 Â TIME= 18:18:04
 This command will be ignored.                      Â *** WARNING ***             CP =    36.375  TIME= 18:18:16
 Element shape checking is currently inactive.  Issue SHPP,ON or     Â
 SHPP,WARN to reactivate, if desired.                  Â *** WARNING ***             CP =   264.672  TIME= 18:22:07
 The Distributed Sparse Matrix Solver is currently running in the    Â
 out-of-core memory mode.  This memory mode may provide significantly  Â
 worse performance compared to the in-core memory mode, depending on   Â
 the amount of available system memory and I/O speed.  Please monitor  Â
 the solver performance to ensure that the large amount of I/O to the  Â
 solver files does not create a bottleneck for performance.       Â *** ERROR ***              CP =   333.172  TIME= 18:23:17
 An input/output error has occurred while trying to open a file with   Â
 length = 33 GB.  Error code = 112, which translates to: There is not  Â
 enough space on the disk.                        Â
 The program is unable to open file file1.DSPtri.  If the suggestions inÂ
 the associated error messages immediately preceding and/or following  Â
 this error message do not help resolve the file issue, please send the Â
 data leading to this operation to your technical support provider,   Â
 along with the I/O error code of -1 and the system error code of 0,   Â
 for help in determining the possible reasons as to why this file could Â
 not be opened.                             Â *** ERROR ***              CP =   333.172  TIME= 18:23:17
 An input/output error has occurred on the process with MPI Rank ID = 1.Â
 This error occurs when trying to open a file with length = 34 GB.   Â
 Please check to make sure there is enough free disk space in the    Â
 working directory (D:Ansys ProjectsG¸ttlerrun-2 -          Â
 v1_filesdp0StudyAIMphysics2) on machine (MARCELL-HPZ4).       Â
Â----
Thanks in advance,
Marcell
July 28, 2019 at 2:43 am
Brian Bueno
Ansys Employeemarcellszeles
I will ask our team of experts and let you know their recommendation.
- The topic ‘AIM APDL Solve Error (input/output error & out-of-core)’ is closed to new replies.
5874
1306
