Age of Air – What are the units ?
    • Weaerodo
      Hi
      I need to calculate the Age of Air
      From the manual I got the udf of diffusivity as follows
      #include "udf.h"
      DEFINE_SOURCE(rt_source,c,t,dS,eqn)
      real source = C_R(c,t);
      dS[eqn]= 0.0;
      return source;
      DEFINE_DIFFUSIVITY(rtd_diff,c,t,i)
      return C_R(c,t)*2.88e-5+C_MU_EFF(c,t)/0.7;
      when I have utilised this udf, by creating a scalar and solving it
      I have got the following result.
      I am not sure about the results, are the units in seconds??
      because I don't think 7 seconds will be the right answer as the domain is larger.
      Apart from this, I have created an injection (massless), and from post-processing, I have calculated the residence time
      I was getting the residence time as 1061 seconds.
      Please suggest me regarding this.
    • DrAmine
      Seconds
      What materials are you using?
    • Weaerodo
      Thanks.
      Do you feel my result is appropriate.?
      Is there a difference between the residence time and age of air?
    • Weaerodo
      The material is air, the density is an incompressible ideal gas.
      Is there anything??
      Are you feeling doubtful about the result?
      How well converged is the scalar? As I don't know the size of the domain I have no idea if it's correct.
    • DrAmine
      If you do not trust your results you might inject a massless particle and check its residence time. We do not know your case, domain extension and boundaries used here so we cannot comment on unknown things.
    • Weaerodo
      Thanks for your responses.
      I understand I should have specified a few details about the domain.
      The domain is 4*2.5*3 (meters).
      Yes, Injection of a massless particle is giving me a value of 1061 seconds, whereas the scalar was giving me 7 seconds.
      Should I go with the injection? (I wonder what was my mistake for the scalar case.!)
    • DrAmine
      No no : check the particle tracks perhaps you have a particle stuck somewhere which is not really what you want to have. Do you have inlet /outlet? More details please........ And what value you have at inlet for your UDS...?
    • Weaerodo
      I have two inlets and two outlets.
      The uds is specified a value = 0 at the inlets (Blue colour in the contour), whereas for all the remaining boundaries I have selected the flux=0.
      Apart from these things, is their any other important thing to consider while solving for the scalar.?
      Do we need to add source in the cell zone?
Viewing 9 reply threads
  • The topic ‘Age of Air – What are the units ?’ is closed to new replies.
