Ansys Products
Ansys Products
Aerofoil and Cylinder with Rotating Wall Boundary Condition
    • Tom Davies
      I am doing a simulation with a cylinder rotating on the top surface of an aerofoil. I want to apply the rotating wall boundary condition to the cylinder, (dont want to use the moving mesh method for simplicity.) Would this be a steady or transient simulation?
      Steady ought to work OK. However, I'd have a very careful look at the cell growth rate and aspect ratio as the images don't look great.
      • Tom Davies
        Thanks Rob, I need to split the domain projection lines into more divisions, which area do you specificy mean?
        The cylinder and aerofoil are connected, and I will just rotate the cylinder wall, this should work ok?
      It should be OK to just set the cylinder wall motion, but check for odd effects at the ends.
      Re the mesh, have a look at the various NACA examples. You need to avoid jumps in cell size but also if you're expecting flow separation to avoid high aspect ratio cells. So, inflation + flow separation isn't good.
      • Tom Davies
        I did a simulation with the wall rotating, and I got CD and CL values very different from when the wall was stationary, but the velocity contours looked ok. I then tried a simulation at an angle of attack and got exactly the same CD and CL.
      Look at the forces too, also check how the NACA wing sets the various constants for lift & drag coefficients.
  • The topic ‘Aerofoil and Cylinder with Rotating Wall Boundary Condition’ is closed to new replies.
