Adding Turbulence to an Internal Boundary
    • maria.marinari
      Hi Everyone,
      I was wondering if anyone knew of a way of adding additional turbulence at an internal boundary. Either through a UDF or an extra boundary condition. The boundary in question already has a fan boundary condition on it, can you add additional boundary conditions to the same boundary?
      If anyone has any ideas I would really appreciate it.
      All the best,
      Maria
      Not at the surface boundary, but you can add "stuff" into cell zones using source terms.
    • maria.marinari
      Thanks so much would I do that using user-defined scalers?
      You can, or just add more "turbulence".
    • maria.marinari
      Ah, right I see. Is there a way to do this just on the cells at the boundary rather than everywhere in the domain?
      Yes and no. There's no reason you can't split some cells to add the source too, so you add it to a whole zone which isn't the same as the whole model. Otherwise you need a UDF; expressions may also work but not sure where we've got re conditional source terms.
    • maria.marinari
      Could I then theoretically write a UDF That creates a cell zone from all the cells directly behind the faces on the boundary and add a source term to them?
      Yes, you'd need to ID the surface, it's normal and then tag the cells. Check expressions too, you may be able to set
      IF  15
      ELSE source = 0.0
    • maria.marinari
      Awesome thanks so much!
      Where would I hook in a udf like that, do you know which macro should I use to base the udf off?
      You'd need DEFINE_SOURCE https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v221/en/flu_udf/flu_udf_sec_define_source.html
    • maria.marinari
      Thanks so much for all your help!
Viewing 10 reply threads
  • The topic ‘Adding Turbulence to an Internal Boundary’ is closed to new replies.
