Adding heat flux to a battery wall.
    • eng_m_m.abd89
      I have a geometry as shown in the attached screenshot; it includes two soldis (the battery and battery wall) and fluid domain surrounding them. The problem includes adding a heat flux to the side surface of the battery wall to represent a heating coil that heats the battery until thermal runaway happens.
      I assume that the heat flux will be added as a boundary condition, but it is not clear where to add it. A screenshot of boundries is shown. Should I define the side of the battery wall as the edge and add it to it? or what?
      Are you adding heat to the battery (solid) or battery case (wall)? The former is a source term, the second would be heat generation if you set the wall & wall:shadow with a thickness.
    • eng_m_m.abd89
      The concept is to add heat flux to the wall, then it should heat up the battery also through conduction, so as I understand now, it shall be added to the wall. shadow considering adding a thickness for conduction to happen? Is my understanding correct?
      The problem in this is that it requires heat per volume, so I have to get the area. I can calculate the area manually, but when I check the area from the surface integral panel, it shows zero value.
      In the wall bc panel you’ll see heat generation rate. The wall has an area, and when you assign a thickness you can calculate a volume. The integrals will return zero as the volume is virtual and doesn’t exist in the geometry. I can make the “thin” wall 1m thick in a 2mm domain if I choose to; it’s wrong but it still fits.
      Leave the "coupled" option for wall & shadow alone.
