January 15, 2025 at 11:33 pm
zxhurs
SubscriberHi everyone,
I am currently working on setting up a short fiber model in the Material Designer module of Ansys Workbench. However, I encountered an issue when trying to perform Curve Fitting. I couldn’t find an option to add experimental data. Under the “Test Data” section, the area is completely blank, and I am unsure how to proceed.
Has anyone faced a similar issue or knows how to resolve this? Any guidance or advice would be greatly appreciated!
Thank you in advance for your help.
January 16, 2025 at 2:15 pm
zxhurs
SubscriberI'm sorry. I found it.😅
January 17, 2025 at 7:11 am
ashish.khemka
Forum ModeratorHello,
Thanks for the update. Can you please provide the answer here so that other members can benefit.
Ashish Khemka
January 17, 2025 at 8:31 pm
January 20, 2025 at 8:21 am
ashish.khemka
Forum ModeratorThanks a lot for sharing the details!
Ashish Khemka
Viewing 4 reply threads
- The topic ‘Adding Experimental Data in Material Designer (Curve Fitting)’ is closed to new replies.
