TAGGED: ansys-mechanical, contact, fluids, system-coupling
January 27, 2022 at 2:22 pm
nilshinzmann
SubscriberHello everyone,
I have a problem with the coupling of a fluid in a steel structure.
 In simple terms, I have a cavity filled with a fluid. The fluid can be considered as incompressible. The steel body experiences a load (external pressure), which causes a deformation of the steel body. The deformation causes a stress change / pressure change in the fluid, which I want to know.
 What could be ways to solve this?
Remodel the fluid (without e-module) in engineering data? The steel body deforms elastically. For a static structural analysis I need elasticity.
or
a FSI in Fluent? What boundary conditions must be met for this? For example, there is no flow in the fluid.
 I am grateful for any help!!
Cheers
January 28, 2022 at 12:53 ampeteroznewman
SubscriberFebruary 8, 2022 at 2:55 pmnilshinzmann
SubscriberThank you Pete!
I created two geometries in SpaceClaim:
1.Solid (Steel) ÔÇô Main Body
2.Fluid (Water) - Cavity
Can I implement the property comment of a fluid (242) Workbench/Modell/Geometry? Right click on the specific geometry lets me insert an APDL Command window.
Cheers Nils
February 9, 2022 at 9:22 pmpeteroznewman
SubscriberYou don't want a solid body for the water. Fluid elements are created by covering the inside of the cavity with surface elements and putting a single node inside the cavity to carry the pressure DOF.
Viewing 3 reply threads- The topic ‘Adding a fluid into static structural analysis’ is closed to new replies.
5879
1306
