Acoustic pressure contours
    • cfd_learner
      I have simulated aerodynamically generated noise using FW-H model in Ansys Fluent. Now, I want to see contours of acoustics waves in cfd-post or Ansys Fluent. How can I get that?
    • Marco Coderoni
      It is not clear what is your final goal. Do you want to plot the contours of the sound waves in the simulation domain? - On the FWH surfaces? - Outside the simulation domain?
      With the FWH model you can plot and analyze the surface pressure levels on the selected FWH surfaces, as described in the User's guide "23.2.6. FFT of Acoustic Sources: Band Analysis and Export of Surface Pressure Spectra". Also you can plot (directly in Fluent) the Surface dpdt RMS on acoustic sources that are defined as walls. Moreover, you can use the model to compute the pressure signal to one or more receiver locations and then use the FFT tool to obtain a local spectra.
      If you are planning to visualize the sound waves inside your domain (on any cut plane of your choice) then it all depends on the simulation settings. If it is a compressible fluid simulation then you can visualize the contours of static pressure (hydrodynamic + acoustic pressure).
      Hope this helps
    • cfd_learner
      I want to visualize sound waves inside the fluid domain, on a cut plane. The simulation is incompressible. Can I visualize in the incompressible situation? If not possible, how to do in the compressible simulation.
      Do you want to plot the contours of the sound waves in the simulation domain? - YES
      On the FWH surfaces? YES
      Outside the simulation domain? How to do in this situation?
      Regards
  • The topic ‘Acoustic pressure contours’ is closed to new replies.
