February 15, 2022 at 9:08 pm
shashank1
Subscriberwhen I validate my design i get an error saying the A and B are intersecting. So when I unite /subtract/intersect A and B it becomes invalid object and returns the following error
Acis error: "Fail to make union..Acis Error 21091 - Two or more vertices of one body mapped to a single entity of other body"
Did any one face similar issue?
February 16, 2022 at 5:31 amKeyur Kanade
Ansys EmployeeAre you using SpaceClaim?
Please check geometry in SpaceClaim.
Select geometry in structure tree --> Use right click --> Select Check Geometry. (Or Tools - Fault Detection in DM)
The geometry should be error free to proceed.
If geometry has any errors, please modify/recreate geometry at those places.
Please go through help manual for more details
Regards Keyur
February 16, 2022 at 5:58 pmshashank1
SubscriberNope, My geometry is in HFSS. I am using human head model in HFSS. I cannot recreate the model in Spaceclaim as the model is complex human body and HFSS wont export the cad file.
February 23, 2022 at 2:33 pmPraneeth
Please share more information about your query to help us serve you better.
It looks like two objects of different materials are intersecting with each other. So subtracting or uniting will not solve your issue if you do not intend.
Does human head model intersect with other objects in your simulation model?
If not, there might be some problem with the human head model as it is a complex model. Kindly go through "Model Preparation Commands" section of the HFSS help document to reduce the errors in the human head model.
All the very best Praneeth.
March 2, 2023 at 3:38 pmha_nguyen3
SubscriberHi @shashank1,
Would you please let me know if you find a solution for this?
When doing validation check, two imported objects intersected, so I tried to do subtraction. But I had the same error about “Two or more vertices of one body mapped to a single entity of other body”. My model is a 3D rat head with 2 layers, skull and outer layer (or muscle) imported into HFSS. I did intersection as recommended in “Model Prep Commands”, and it gave me below image. I tried every options in that section, but none seems to work.
Thanks
Viewing 4 reply threads- The topic ‘Acis Error 21091’ is closed to new replies.
6750
1324
1087
