September 22, 2022 at 10:33 am
naftali.herscovici
SubscriberHello,
I know SpaceClaim can be accessed form Python, but have not seen anything regarding access from Matlab or VBA.
Does anybody have a script that can control SpaceClaim from Matlab or VBA?
Thank you
September 23, 2022 at 1:53 pm
Rahul Kumar
Ansys EmployeeHello,Â
I would suggest to get in touch with Matlab support for this.Â
- The topic ‘access SpaceClaim from Matlab and/or VBA’ is closed to new replies.
- Lumped Port Deembed
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- Hfss 3D pcb via capped and filled with epoxy
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- AEDT Natural Convection with default correlation is failing solver initializatio
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
- Co-simulation in Q3D, Icepak – meshing problem
1487
1318
1171
