Access “Read Results Files” in Ansys Workbench Mechanical
    • Lucie
      I do some calculus in Static Structural. I create my model on my computer using Ansys Workbench and I use the function "Tools > Write Input Files" to create a file .dat. Then I put this file.dat on a server where I solve my model using APDL in Batch. Then I import all the results on my computer in the same folder where I have my .wbpj and I use the function "Tools > Read Results Files" to open the results in Workbench.
      Sometimes it works very well, and sometimes the function "Tools > Read Results Files" is grey and I cannot access it in Workbench. What can I do to solve this problem ?
      - There is no big difference between my files that are working and the ones that don't. (Sometimes it is just a model I copy paste and changed the size of the mesh for example).
      - I followed the instructions of the User's Guide : I use an APDL command in Workbench, the files have the same name, they are stored in the same folder as my .wbpj, I have the .rst and .err together (with all the others : .out, .db, .log ....etc.) and of course I highlight the "Solution" before.
      - I have no problem with my licence (I have Teaching and Research Academic v14).
      - The size of the result doesn't seem to influence
      - I have cleared the solution data, so my model is asking for a Solution
      - I have compared the options between the files working and the files that are not working and they are the same.
      Thank you so much for your help !
    • Sandeep Medikonda
      What version are you using? Is it v14?
      This is a very old version so even if this is a bug, it can't be reported to development.
      Please try it with a newer version (latest is 2019R1 and can be downloaded by clicking on the banner at the top) and let us know if you still encounter this.
    • Lucie
      Thank you for your reply.
      Yes I am using the v14 because it is a modelisation for the laboratory of my University, so I use their Research Academic licence.
      I "solved" the problem by deleting my mesh and do it again exactly the same way. It takes some time to do but at least after I have everythings that works.
    • JuanManuel
      Hello,nI am trying to do the same thing but I don't get to solve the file.dat in batch mode. I haven't found the part in the documentation which Lucie is referring to. nWhich chapter it is in or if anyone can explain the process please.n
  • The topic ‘Access “Read Results Files” in Ansys Workbench Mechanical’ is closed to new replies.
