TAGGED: #motor-cad, copper-loss, error, litz-wire, pmsm
September 12, 2024 at 3:59 pm
peter-michael.ullrich
SubscriberHello together,
maybe someone can help me with my issue. In Ansys MotorCAD i want to simulate the AC Losses of my motor with Litz Wires. If i use a template motor the calculation shows no problem.Â
If i use my custom motor with "normal" widining like hairpins everything works as well. As soon as i use litz wires in the middle of the calculation process i get the error: "Could not find variable in multithreaded solution: ACCopperLoss_C1"Â
Does anyone has an idea what can cause this issue?Â
Thanks.Â
October 2, 2024 at 8:51 pm
HDLI
Ansys EmployeeHello Peter-michael.ullrich,Â
   Could you share the screed copy for winding setting for Litz wire? Could you try the latest Motor-CAD version? Which version are you using?
HDLI
