Photonics
Photonics
About Thin Film Simulation (FDTD)
    • 2212296
      Hi guys! In a recent question, I learned that thin films can go on to measure refractive transmittance by the 'stackrt' method.
      Question: 'stackrt' method compared to regular method
      1. The difference between the scope of use of the two (which case is applicable)
      2. Is there any difference between the measurement results of the two?
    • Guilin Sun
      stackrt is an analytical solution for thin-film type of devices : https://optics.ansys.com/hc/en-us/articles/360034406254-stackrt-Script-command
      You can compare some simple analytical results such as a cavity that many textbooks have formulas that you can use.
  • The topic ‘About Thin Film Simulation (FDTD)’ is closed to new replies.
