November 3, 2021 at 4:56 am
ssssss
SubscriberHi all,
I am trying to transfer the results of the an Abaqus analysis to Ls-Dyna and continue my analysis in Ls-Dyna (initial stress-stress-deformed shape etc.. will be the output of the Abaqus results). I was wondering if there is a way of doing that?
Thanks
November 3, 2021 at 9:07 amErik Kostson
Ansys EmployeeHi
ODB result files can not been opened/used in LS-Dyna.
LS Pre Post can though import to a certain extent abaqus .inp file which are text files.
All the best
Erik
November 3, 2021 at 2:44 pmssssss
SubscriberThank you very much Erik, is there a way to transfer Abaqus output so that Ls-Dyna could import and read? I have tried Nastran but I guess it accepts the undeformed model (the job file (.inp)) file but not the output one
Thank you very much once again
November 24, 2021 at 12:44 amvikaskaul
SubscriberIf it is just the deformed shape, then all you need to do is export the mesh (using the Python API that comes baked in with the Abaqus/Viewer, perhaps), do some basic manipulation of the text file so that it can be read by LS-DYNA.
On the other hand, if you are thinking of consuming stress/strain/.. fields from one solver to another, chances are you are better off switching straight to Dyna and doing it all in one code. Otherwise, it is going to be a non-trivial undertaking.
Viewing 3 reply threads- The topic ‘Abaqus odb to Ls-Dyna.k’ is closed to new replies.
3862
1414
1220
1118
1015
