August 12, 2024 at 9:45 pm
jdidd1
SubscriberHello,
I am new to the thermal-electric. I am doing a research on PCB (Thermal-electric), while doing the analysis I got the error and warnings about the solver pivot I don't know what to do. The mesh connectivity is good, But in the error its showing the node 4817 for easy reference I attached the snips. Please help me to get the result.
August 13, 2024 at 1:33 pm
Gary_S
Ansys EmployeeIn the Analysis Settings in the tree, set Solver Controls > Solver Pivot Checking OFF then see if the solution runs.Â
August 13, 2024 at 1:47 pm
jdidd1
SubscriberThank you for the reply, I turned off the solver control but still the same problem existsÂ
August 13, 2024 at 1:54 pm
Gary_S
Ansys EmployeeTry a simple thermal analysis. Perhaps a given Tempatrure on a face anywhere in the model, and a Convection - Stagnant Air over all.Â
See if if solves. -
August 13, 2024 at 2:06 pm
jdidd1
SubscriberActually, this come under joule heating. Passing certain voltage to the copper coils in the PCB and see how the temperature distribution works.
I think the thermal analysis will not help in this case. Am I right?
August 13, 2024 at 6:02 pm
mjmiddle
Ansys EmployeeÂ
Gary’s suggestion to use a thermal analysis was only as a diagnostic. We do a similar thing to test rigid body motion in a static structural analysis by running a modal analysis. There are no contacts in your model. Do not rely on an image to assume mesh is connected since it often uses the same mesh size on both sides of touching bodies with default sizing and may appear as connected. You will need to connect these bodies using shared topology in SpaceClaim or DesignModeler or use contacts in Mechanical.
5719
