September 10, 2021 at 6:45 am
dyh
SubscriberI am using VOF-to-DPM model to simulate the metal liquid breakup in airflow. The result is shown in picture.
September 10, 2021 at 9:15 amAmine Ben Hadj Ali
Ansys EmployeeYou are probably using a small split factor and for that reason Fluent is creating several particles out of the transitioned VOF ligament. We usually use a very high value to avoid splitting and keep single droplet parcels. Can you check your settings?
September 12, 2021 at 9:56 amdyh
SubscriberThank you for your replying.
The setting which you mentioned is 10, which is default setting for FLUENT. How much should I increase to? 50, 100 or more?
Viewing 2 reply threads- The topic ‘A Question of VOF-to-DPM model in Fluent 2021’ is closed to new replies.
4818
1587
1386
1242
