January 30, 2025 at 6:49 pm
r.kliza
SubscriberHiÂ
I have a problem with compiling UDF file in fluent 13.0. I imported the 2D computational mesh of my model in .nas format from COMSOL. I loaded it into Fluent. I then tried to compile the UDF with a sequence: Define>User-defined>funtcions>compiled. I then loaded the required file with the .c extension, clicked Build and then Load and this message appears:Â
The UDF library you are trying to load (C:\Program Files (x86)\Elektroaero\Comsol-Fluent\libudf) is not compiled for 2ddp on the curent platform (win64). The system cannot find the specified path. C:\Program Files (x86)\Elektroaero\Comsol-Fluent\C:\Program Files (x86)\Elektroaero\Comsol-Fluent\libudf\win64\2ddp\libudf.dll.Â
Anyone have an idea how to solve this problem.Â
Kind regards
Rafał
January 31, 2025 at 9:57 am
Forum ModeratorI'm not even sure v13 was compiled for 64bit, please can you check the install? From memory, v13 is from about 2008 so you may want to update.Â
February 3, 2025 at 7:27 pm
r.kliza
SubscriberThanks Rob. I
m tried to build my model again in Fluent 2023 but there is another problem. This time I cant even load my mesh in NASTRAN file (.nas) into my case. Mesh becomes from COMSOL Multiphysics and during loading mesh appears this error: "Cleanup script file is C:\Users\superkomp2\Desktop\Elektroaero\Comsol-Fluent\cleanup-fluent-superkomp2-22100.bat
Reading "C:/Users/superkomp2/Desktop/Elektroaero/Comsol-Fluent/Mesh.nas"...
Warning: no nodes readanalyzing boundary connectivity...done.
Meshing> Reading "| utility fe2ram -tNASTRAN -s -d3 C:/Users/superkomp2/Desktop/Elektroaero/Comsol-Fluent/Mesh.nas"...
Warning: no nodes readanalyzing boundary connectivity...done."Â
So this is error with import a .nas mesh file to Fluent but I don
t understand what Im doing wrong.ÂBest regardsÂ
Rafał
February 4, 2025 at 11:41 am
Forum ModeratorTry reading the mesh into Fluent Meshing and see what comes in.Â
February 10, 2025 at 1:23 pm
r.kliza
SubscriberHi ROBÂ
Thank you for your reply. Import of mesh in nastran file from comsol to fluent 2023 was successful. However, in version 2023, the UDF file completion problem is still the same as in version 13.0 - fluent cannot find the 2ddp libudf.dll library in the selected directory. Strange. How can I solve this problem? Â
February 10, 2025 at 4:45 pm
Forum ModeratorÂ
You need to compile the UDF. Open Fluent in 2d dp and compile the .c file (use the built in compiler) and look for errors. Assuming it works, read in the case/mesh you’ve already got working.Â
Edit. Check the UDF macros in the newer documentation as a few calls have changed over the years to simplify and/or extend functionality.Â
February 24, 2025 at 10:35 pm
r.kliza
SubscriberÂ
Hi Rob. The problem with compling UDF file is solved. But I have another problem. After hybrid initialization of my case appears this message:Â
Node 1: Process 16788: Received signal SIGSEGV.
= BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
= RANK 0 PID 6924 RUNNING AT superkomp
= EXIT STATUS: -1073741819 (c0000005)
= RANK 1 PID 16788 RUNNING AT superkomp
The fl process could not be started.Â
What means f1 process?
February 25, 2025 at 1:37 pm
Forum ModeratorIt's "fl" or "FL" so means the Fluent process. SIGSEV typically means you've got a problem with data somewhere: Fluent needs something and it's not available. Now the UDF compiles you may need to focus on what data it requires and what data is supplied to Fluent.Â
February 27, 2025 at 9:59 pm
r.kliza
SubscriberRob, thanks for another answer. Could you tell me please where I should searching for error? I understood that .udf file could consist some kind of mistake in code? I haven`t any idea where I should start searching for error. Maybe more precisly, how to find what kind of data are required for Fluent and which data are missing?
February 28, 2025 at 10:26 am
Forum ModeratorIf the code compiles then it's "good". However, you may be returning a nonsensical number to the solver. If you alter the UDF to put it's output to a UDM rather than the code what is it doing? Or change a UDF variable output to a constant to check what's going on. Trouble shooting is pretty much a case of turning things off until it works and then turn it back on until it breaks.Â
