LS Dyna
LS Dyna
A large beam mesh model won’t load
    • javat33489
      Hello everyone. I'm modeling a huge beam mesh model.
      It's a 100x50 meter mesh made of 6mm wire, using a beam model with a 100x100 mm mesh size. I created a Workbench-Share  to combine all the beams into one piece and connect all the nodes. This resulted in a gigantic beam mesh model.
      When I open Workbenches Dyna, it takes a very long time to load. I've waited three days, but it still hasn't loaded. How do I load it? Are there any ways to speed it up?
      Thanks.
    • erik.kostson
      It is difficult to investigate this issue without access to the model. Since you have a large model and, I assume, a commercial license with support entitlement, I recommend submitting the case to ACSS Support. We can then review the model and help determine the root cause of the behavior you are experiencing.
      Best regards,
      Erko
