A FAILURE OCCURED INSIDE THE MESH REFINEMENT MODULE
    • mmrhwb
      When I am trying to do the automated mesh convergence study by using the adaptive meshing technique in Ansys 19.1, I am getting the error message as "A FAILURE OCCURED INSIDE THE MESH REFINEMENT MODULE". Did anyone else face this issue as well? What would be the possible reasons and how could I solve this? I would appreciate your help with this.
      As a workaround, do the mesh convergence study manually.
      • Create a coordinate system at  the peak stress location.
      • Create a Body Sizing Sphere of Influence around the peak stress using the coordinate system above.
      • For the element size, you can click the P button to turn that into an input parameter.
      • On the maximum stress result, click the P button to turn that into an output parameter.
      • Double click on the Parameter Set box in Workbench.
      • Now you can enter a set of element sizes in the Design Table, and hit the Update All Design Points button.
      • When the solver finishes, you can plot the data.
    • mmrhwb
      Thank you so much for your great suggestion.
      I will do it this way.
  • The topic ‘A FAILURE OCCURED INSIDE THE MESH REFINEMENT MODULE’ is closed to new replies.
