March 23, 2020 at 9:31 pm
Yarrius42
SubscriberI have been using my schools Virtual Desktop Interface (VDI) to run simulations in ANSYS 2019R3, but with the increase demand on their network along with more students trying to access the VDI I have decided to try and run the simulations from home using the student version of ANSYS 2020. I was able to extract all the files and folder structure and open up one of the simulations that converged in the VDI environment. When I try to rerun the same (solution method, Boundary Conditions, Residual requirements, etc) file I am not getting a solution that converges. In the 19R3 version the simulation converged around 250 iterations, but now in the 2020 version I have fun 2000 iterations without a convergent solution. Would there be something that has changed in the software that would cause a difference in how calculations are being performed? Has anybody else run into similar issues?
Thank you
March 24, 2020 at 3:51 am
Keyur Kanade
Ansys Employeeif you are getting converged solution in 19.3 then you also should get it in 2020R1.
please cross check all your input conditions.
what is your application? what settings are you using? are able reproduce similar difference on any simple case like flow through pipe?
Please post the questions in appropriate category. Moving this question to other category to get better response.
Keyur
If this helps, please mark this post as 'Is Solution' to help others.
March 24, 2020 at 9:23 pm
Yarrius42
SubscriberI am simulating flow through a 2D pipe that is getting smaller as it goes downstream. Both simulations are using double precision, 2D solver, with Energy and standard k-e, standard wall fn and all the other models are off. I have the same materials and boundary conditions in both simulations as well. The outlet is pressure outlet with a target mass flow rate and preventing reverse flow, the inlet is also prevent reverse flow. Both have no heat transfer properties on any of the walls. All of the solution methods are the same and the monitors are set to the same values. All of the values and options that I have put into the 19.3 solver on the schools virtual computer are identical to the inputs I have put in the 2020 solver on my computer.
I have not attempted a simpler model yet to see if I get similar issues. That will be the next step of trying to troubleshoot if I can't isolate another potential input that might be different between the two versions.
Thank you for moving the question.
March 24, 2020 at 9:34 pm
Yarrius42
SubscriberNot to add any more confusion, but after verifying all of the options were the same, which they were and no updates, I attempted to rerun the information to see if any of the data points at the end of 500 iterations would help me try to troubleshoot. This time my solution converged and matches everything that was in the previous solution. I'm not sure what changed except closing ANSYS out yesterday and reopening it today, but things seem to be working now. Hopefully this is just one of the glitches that I seem to be able to find across multiple platforms now.
Thank you for reviewing this.
March 26, 2020 at 3:44 am
Keyur Kanade
Ansys EmployeeGlad that it is resolved. Can you please mark this as 'Is Solution' to help others on community.
Keyur
- The topic ‘2020 R1 vs 2019 R3’ is closed to new replies.
3029
971
858
836
777
