Ansys Learning Forum › Forums › Discuss Simulation › 3D Design › Spaceclaim, Copy lines and curves to a new design leads to garbage › Re: Spaceclaim, Copy lines and curves to a new design leads to garbage
Charudatta Bandgar
Hello SC-FEMART
If I understood correctly, the curves used to get imported as a single curve, and with the newer versions, it is getting split into individual lines. Can you please tell me which version of SpaceClaim you were using previously? Also will it be possible for you to send me the file so that I can test it on my end?
Regards
