Ansys Learning Forum Forums Discuss Simulation 3D Design Product guide & tutorials as per 2022 R2 i.e. Bolt Flange Joint Gasket analysis etc Re: Product guide & tutorials as per 2022 R2 i.e. Bolt Flange Joint Gasket analysis etc
Charudatta Bandgar
SagarLive I will have to check if that is possible, my understanding is it might not be possible directly as the rubber gasket would perhaps need non linear material properties and this will be fluid + structural simulation. Let me check and get back to you if there is a feasible way to do it.
Also, if it is possible for you to share the workflow you would use in other products that you generally use for this kind of simulation, I can provide a workaround that might be possible in Discovery.
