Ansys Learning Forum › Forums › Discuss Simulation › 3D Design › Product guide & tutorials as per 2022 R2 i.e. Bolt Flange Joint Gasket analysis etc › Re: Product guide & tutorials as per 2022 R2 i.e. Bolt Flange Joint Gasket analysis etc
Charudatta Bandgar
Hello SagarLive
I do not have a tutorial for this, but please find the video I created explaining how to do a bolted joint analysis. You can also go through this knowledge material, and try the run there. Or go through these documentations to understand how to define bolt preload or use bolt assign tool.
SagarLive said:
1) After opening Creo files directly opening data in Creo instead DSL
Let me check this with the team.
SagarLive said:
2) Lic not getting for ansys user etc.
 What error are you getting for them?
​ 🛈​ This post originally contained file attachments which have been removed in compliance with the updated ​ Ansys Learning Forum Terms & Conditions​
