Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › How do I get deformed geometry › Reply To: How do I get deformed geometry
There are two approaches to get the deformed geometry out of a Static Structural solution into a CAD program: a two step process and a fifteen step process. Thanks to SimuTech group for teaching me this method.
FOR VIEWING OUTSIDE FACES ONLY
In Mechanical: Insert a total displacement for a selected body into the solution, then right click on it and export an stl file. Â
In CAD:  import the stl file. Some CAD systems don't handle imported stl files very well. New versions are getting better at that. See the next approach.
TO CREATE A SOLID BODY (more useful in CAD programs)
Here are the steps to export a Parasolid file:
In Mechanical:
- Create a Named Selection named "top" that contains the part you want to export.
- Analysis Settings set to Save APDL db
- Drop a Mechanical APDL component onto the Static Structural SolutionÂ
- Right click on Analysis row of Mechanical APDL system on project page and select "Add Input File"Â
- Select attached input file upgeom.inp (this is setup to select a single part in your model).
- Drop an FE Modeler component onto the Mechanical APDL Analysis
- Update the Static structural solution, Mechanical APDL Analysis, and FE modeler.Â
If the Static structural solution was done before step 1 above, clear generated data first.
Open FE Modeler
8. Right click on "Geometry Synthesis" and select "Insert>>Initial Geometry"
9. Right click on "Initial Geometry" and select "convert to parasolid"
10. Drop a DesignModeler (Geometry) Component onto FE modeler Model cell
11. Update FE modeler and DM
Start DM (double click on Geometry field)
- Add a Body Operation, "Type" set to Sew, setting the "Create Solids?" to Yes
If the result is not a single solid, change "Tolerance" to User Defined.
13. In DM open Tools>>Options then go to:
DesignModeler>>Geometry>>Export Options>>Parasolid Export Version and select 24.0 for NX8
14. Export Parasolid file.Â
15. In CAD system import Parasolid file.
