Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Errors with multi-connected bodies using AQWA › Reply To: Errors with multi-connected bodies using AQWA
oe23m012
Thank you,
I tried to give single joint, single fender and single cable and still it is not converging
and with normal program controlled settings i am getting this error
I tried another iteration with single joint and multiple cables and fenders this is also having problem in both.
