Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Body mistakingly imported as flexibel instead of rigid › Reply To: Body mistakingly imported as flexibel instead of rigid
January 9, 2025 at 3:42 pm
Hi,Â
Check the Engineering data and you should see the *MAT_RIGID card this will set the body rigid in the .k file, so this "flexible behavior" can be ignored.Â
To check, export .k file from this stage and open it with Notepad to see if this material card is set.
Cheers, RamÂ
