Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Errors with multi-connected bodies using AQWA › Reply To: Errors with multi-connected bodies using AQWA
January 9, 2025 at 9:51 am
I guess that you used two joints on the deck in this calculation. If it is true, could you please just use one hinge joint only? For rigid body response analysis of this model, the socond universal joint has no effect on the motion responses, but may cause the singularity problem of the response equations.
