Ansys Learning Forum Forums Discuss Simulation Electronics EV MCU thermal simulation Reply To: EV MCU thermal simulation
Rabindra Paul
Hi – From the message it looks like you are the customer of channel partner CADFEM so you should get support through them. If needed CP will create a support case with Ansys. Please check with your license admin or collegaue to get CP support information. Hope this helps.
