Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Errors with multi-connected bodies using AQWA › Reply To: Errors with multi-connected bodies using AQWA
oe23m012
 Hello sir,
Thank you for the responce
(1) in Stability analysis, using small Movement Limitations per iteration and small Maximum Error in Equilibirum Position.
And i am getting the above error at 13696 iteration
(2) Using small time step in time domain analysis.
The error is consistent with several iterations
