Ansys Learning Forum Forums Discuss Simulation Electronics EV MCU thermal simulation Reply To: EV MCU thermal simulation
Rabindra Paul
Hi rbj, Thanks for asking questions in forum. For first question, I think using average value is a good choice. To model, worse case scenario, you may use some percentage larger than the average. For your other question, I would suggest to create a support case as engineer will need to review the setup and check the model. It seems you are linking with another model and the project is not getting the solution from other model. Please create a case and one of our support engineers will get back to you.
Regards
