Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Flexible Material Plugin Issue › Reply To: Flexible Material Plugin Issue
January 8, 2025 at 7:35 pm
Thank you everyone.
Kyle it seems that I can not download Visual Studios 2013 and unfortunately have to use 2022. When I build the solution after making a .dll project, it seems the immaterialplugin.h file seems to be the main problem. I keep getting an unexpected end of file error. Do you guys have a version that works with newer versions of Visual Studios?
