Ansys Learning Forum Forums Discuss Simulation LS Dyna Compression of a rubber sample in LS Dyna ACT Workbench Reply To: Compression of a rubber sample in LS Dyna ACT Workbench
Ram Gopisetti
Set the contacts behaviour to program controlled but for SPH it automatically scopes it as node_to_surface contact.
Navigate to the solution directory, and please review d3hsp for more information on the errors and post it here for further recommendations.
Also, ensure you are taking care of higher-order elements like pyramids in your model.
Cheers, Ram
