Ansys Learning Forum Forums Installation and Licensing Ansys Products UI glitches in DesignModeler and Meshing Reply To: UI glitches in DesignModeler and Meshing
ap222123
Thank you for the reply. Unfortunately, I can't seem to find the .ansys file anywhere I look. I tried the path you provided and several others, but it appears that the file in question is simply missing from my laptop. Yes, I also enabled the viewing of hidden files. The only file I was able to find is .fluentconf, and I tried your fix with it just for good measure, but it didn’t do anything. I also wanted to try setting the DesignModeler default graphics setting to integrated graphics in the NVIDIA Control Panel, but I couldn’t find the DesignModeler.exe file either—only the Workbench.exe.
