Ansys Learning Forum Forums Installation and Licensing Ansys Products UI glitches in DesignModeler and Meshing Reply To: UI glitches in DesignModeler and Meshing
V.P
Hi
Close the CFD post first. Then rename the .ansys file in your user profile folder. You can find .ansys file inside the "C:\Users\username" folder. Rename .ansys to .ansys_backup.
Now you can try opening again and see if the issue remains.
