Ansys Learning Forum › Forums › Discuss Simulation › Electronics › Adding and deleting vertices in an existing polygon in HFSS 3D Layout › Reply To: Adding and deleting vertices in an existing polygon in HFSS 3D Layout
Rong Liu
Hi, sorry for the inconvienence but there is a way to work around it.
You can use Draw-->Primitive to draw an additional polygon and use Draw-->Merge Polygons (union or subtract) to add or delete vertices.
Best regards,
Rong
