Innovation Space Logo
FREE STUDENT SOFTWARE Login
  • Community
  • Learning
  • Support
  • Educator
  • Career
  • Maker
  • AnsysGPT
  • Learning Forum
Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › AnsysWBU.exe encountered a problem == (R2 2024 Student Version) › Reply To: AnsysWBU.exe encountered a problem == (R2 2024 Student Version)
January 7, 2025 at 11:56 am
Harshvardhan
Here are some links related to similar issues:
Error: Unable to start Mechanical in Workbench WINDOWS “AnsysWBU.exe encountered a problem. A diagnostic file has been written: C:UsersusernameAppDataLocalTempAnsysWBDumpFile.dmp” and “AnsysWB Module has stopped working: A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available.” | Ansys Knowledge
AnsysWBU.exe encountered a problem…
I hope this helps.
Harshvardhan
Ansys Help
Ansys Learning Forum (Rules & Guidelines)
Connect with Ansys
  • Legal Notice
  • Privacy Notice
  • Cookie Policy
  • Export Compliance
  • Terms and Conditions
  • Report Piracy
  • Forum Rules & Guidelines
  • Site Map
© 2025 Copyright ANSYS, Inc
Please Login to Report Topic
Please Login to Share Feed
Harshvardhan
Cancel Save Reply as Draft Publish
Edit Discussion
Avatar
Harshvardhan
Add Tags
Cancel Save Draft Publish
You are navigating away from the AIS Discovery experience
Proceed
Continue
Ansys Assistant
Welcome to Ansys Assistant!
Login
Ansys Commercial Customers: Go to AnsysGPT
Your chat history is not stored
Hey there, you are quite inquisitive!
You have hit your hourly question limit.
Please retry after '10' minutes.
For questions, please reach out to ansyslearn@ansys.com.
RETRY
Are you sure you want to leave? The window will be closed.
OK
