Ansys Learning Forum › Forums › Discuss Simulation › Photonics › The meaning of user a matrix › Reply To: The meaning of user a matrix
Kirill
Dear Subscriber,
For EME simulation results, please refer to the following resources: the EME Solver analysis window overview, particularly the S-matrix mapping section, as well as the associated application examples, such as waveguide Bragg gratings and  fiber Bragg gratings.
Regarding temperature dependency: unfortunately, no. If the material type is set to 'Sampled 3D Data,' it does not support temperature dependency. You will need to create a custom material with a defined temperature dependency. Please refer to the article Temperature dependent refractive index models for guidance.
Best regards,
Kirill
