Ansys Learning Forum Forums Discuss Simulation LS Dyna Compression of a rubber sample in LS Dyna ACT Workbench Reply To: Compression of a rubber sample in LS Dyna ACT Workbench
javat33489
Thanks for the reply sir.
Also, do you need an Asymmetric behavior here as it creates _NODES_TO_SURFACE keyword and is unnecessary in your model.
I didn't understand, should I use asymmetric contact or not?
