Ansys Learning Forum › Forums › Discuss Simulation › Fluids › General connection between main flow path and circumeferential groove in CFX › Reply To: General connection between main flow path and circumeferential groove in CFX
V.P
The reason is that the distance between the interface faces is above the tolerance level. You have to keep both of them very close to achieve a proper connection. Otherwise, it creates a non-overlap condition. Try to make this as close as possible to avoid such problems.
You can check whether the interfaces are in non-overlap condition or not, using contours in CFD-Post. Select the shroud boundary, and create a contour using the variable "Nonoverlap Fraction"
If the boundaries overlap, that section will be colored blue (value =  0), if there is no overlap, then that region will be colored red (value =1)
