Ansys Learning Forum Forums Discuss Simulation Fluids Errors with multi-connected bodies using AQWA Reply To: Errors with multi-connected bodies using AQWA
Shuangxing Du
If the stifnesses of cables and fenders are realistic, please (1) in Stability analysis, use small Movement Limitations per iteration and small Maximum Error in Equilibirum Position. (2) Use small time step in time domain analysis.
