Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Errors with multi-connected bodies using AQWA › Reply To: Errors with multi-connected bodies using AQWA
Thanks for the reply
The high stiffness in cable is required to simmulate the Hydraulic cylinder so that the hulls don't move away because of the large hydrostatic forces exerting on the hulls away from the centerline.Â
And the same thing withe fender stiffness tosimmulate the metal to metal contact between hulls so the arrangement between hinge, cable and fender will act like a class 3 leverÂ
Anyway i tried the analysis with the reduced stiffnessÂ
The inital length is reduced to simmulate the initial tension the cylinderÂ
and the time doamain analysis gave error like this with a very small time step
And then stability analysis with following settings
But it stopped at 13696 iteration and throwed the above error so i gave 13000 iteration to get the idea of hinge load
Still the load is heigh
and with program controlled setting the following error came
So is there any chance to simmulate the Split hopper barge physics in ansys aqua.Â
