Ansys Learning Forum Forums Discuss Simulation Fluids Two-way FSI: excessive thickness change Reply To: Two-way FSI: excessive thickness change
Rahul
This suggests that despite your efforts so far the motion is still numerically unstable. Try even smaller time steps.
Also, check if the QN-stabilization option helps. With this option make sure you set enough coupling iterations that the coupled step converges.
