Ansys Learning Forum › Forums › Installation and Licensing › Ansys Free Student Software › Application of convective heat transfer coefficient equation in CFD-Post › Reply To: Application of convective heat transfer coefficient equation in CFD-Post
OK. In Fluent create the same surfaces using the isosurface tool and have the vessel wall selected when you apply the operation. That gives you a line on the surface. Create the same surface with the wall deselected. You can get the plane & wall surface temperatures at that position.  In the experiment I assume you use that data to then find the HTC?
