Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Getting temperature at specific position using UDF in fluent › Reply To: Getting temperature at specific position using UDF in fluent
January 2, 2025 at 12:15 pm
You may also find the parallel chapter in the UDF manual to be helpful. That way you can run parallel and only do the check once.Â
However, if you don't need the value in a UDF for additional processing you may find a monitor to be sufficient.Â
