Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Unable to run lsrun on HPC cluster › Reply To: Unable to run lsrun on HPC cluster
rajesh.pamarthi2711
Hello Reno,
Using
#SBATCH --nodes=1
#SBATCH --ntasks=24
module load GCC/13.2.0 intel-compilers/2023.2.1 impi/2021.10.0 Python/3.11.5 SciPy-bundle/2023.12 matplotlib/3.8.2 LS-DYNA/14.1.0
  12003 t 6.0000E-04 dt 5.00E-08 write d3plot file            12/31/24 00:15:02
 *** termination time reached ***
   12003 t 6.0005E-04 dt 5.00E-08 write d3dump01 file          12/31/24 00:15:07
   12003 t 6.0005E-04 dt 5.00E-08 flush i/o buffers            12/31/24 00:15:07
   12003 t 6.0005E-04 dt 5.00E-08 write d3plot file            12/31/24 00:15:12
 N o r m a l    t e r m i n a t i o n                          12/31/24 00:15:12
 S t o r a g e   a l l o c a t i o n
 Memory required to complete solution (memory=   5235K memory2=   2930K)
          Minimum   2431K on processor    23
          Maximum   2930K on processor     4
          Average   2525K
 Matrix Assembly dynamically allocated memory
          Maximum    210M
 Additional dynamically allocated memory
          Minimum    202M on processor     2
          Maximum    473M on processor    23
          Average    258M
 Total allocated memory
          Minimum    414M on processor     2
          Maximum    685M on processor    23
          Average    470M
 T i m i n g   i n f o r m a t i o n
                        CPU(seconds)   %CPU  Clock(seconds) %Clock
  Keyword Processing ... 5.0480E+00    0.00     5.1508E+00    0.00
  MPP Decomposition .... 1.8137E+01    0.01     1.9138E+01    0.01
    Init Proc .......... 1.2349E+01    0.01     1.2409E+01    0.01
    Translation ........ 5.3905E+00    0.00     6.3184E+00    0.00
  Initialization ....... 7.9393E+00    0.00     8.2971E+00    0.00
  Element processing ... 1.5533E+01    0.01     1.1069E+02    0.05
    Solids ............. 1.4591E+01    0.01     7.6382E+01    0.04
    E Other ............ 1.1606E-01    0.00     1.0958E+01    0.01
  Binary databases ..... 4.1119E+01    0.02     9.0722E+01    0.04
  ASCII database ....... 1.2786E-01    0.00     1.7478E+01    0.01
  Contact algorithm .... 2.4563E+01    0.01     9.5649E+01    0.04
    Interf. ID         1 1.5629E+01    0.01     6.0890E+01    0.03
    Interf. ID         2 6.3305E+00    0.00     7.0120E+00    0.00
  Rigid Bodies ......... 9.1020E+00    0.00     3.3813E+01    0.02
  EM solver ............ 1.9958E+05   96.01     2.0555E+05   95.93
    Misc ............... 2.3263E+04   11.19     2.4359E+04   11.37
    System Solve ....... 1.4140E+05   68.02     1.4400E+05   67.21
    FEM matrices setup . 3.6113E+03    1.74     3.9420E+03    1.84
    BEM matrices setup . 7.1746E+03    3.45     7.5619E+03    3.53
    FEMSTER to DYNA .... 1.1102E+04    5.34     1.1983E+04    5.59
    Compute fields ..... 1.3031E+04    6.27     1.3704E+04    6.40
  Time step size ....... 8.1400E+03    3.92     8.1801E+03    3.82
  Others ............... 2.0477E+00    0.00     2.8137E+01    0.01
    Force Sharing ...... 1.8586E+00    0.00     1.1413E+01    0.01
  Misc. 1 .............. 2.7344E+00    0.00     4.5960E+01    0.02
    Update RB nodes .... 9.3052E-01    0.00     5.1470E+00    0.00
  Misc. 2 .............. 1.2236E+00    0.00     1.8888E+01    0.01
  Misc. 3 .............. 2.6780E+01    0.01     4.3281E+01    0.02
  Misc. 4 .............. 3.2197E-01    0.00     1.3296E+01    0.01
    Apply Loads ........ 1.3152E-01    0.00     1.0552E+01    0.00
  T o t a l s            2.0788E+05  100.00     2.1426E+05  100.00
 Problem time       =    6.0005E-04
 Problem cycle      =     12003
 Total CPU time     =    207879 seconds (  57 hours 44 minutes 39 seconds)
 CPU time per zone cycle  =      71866.657 nanoseconds
 Clock time per zone cycle=      74073.168 nanoseconds
 Parallel execution with     24 MPP proc
 NLQ used/max                64/    64
  C P U   T i m i n g   i n f o r m a t i o n
  Processor   Hostname                              CPU/Avg_CPU  CPU(seconds)
  #       0   n1680                                     0.99346   3.6269E+05
  #       1   n1680                                     1.00936   3.6849E+05
  #       2   n1680                                     1.00890   3.6833E+05
  #       3   n1680                                     1.00889   3.6832E+05
  #       4   n1680                                     1.00896   3.6835E+05
  #       5   n1680                                     1.00898   3.6835E+05
  #       6   n1680                                     1.00914   3.6841E+05
  #       7   n1680                                     1.00893   3.6834E+05
  #       8   n1680                                     1.00907   3.6839E+05
  #       9   n1680                                     1.00958   3.6857E+05
  #      10   n1680                                     1.00812   3.6804E+05
  #      11   n1680                                     1.00897   3.6835E+05
  #      12   n1680                                     1.00882   3.6830E+05
  #      13   n1680                                     0.80560   2.9411E+05
  #      14   n1680                                     1.00894   3.6834E+05
  #      15   n1680                                     1.00934   3.6849E+05
  #      16   n1680                                     1.00934   3.6849E+05
  #      17   n1680                                     1.00948   3.6854E+05
  #      18   n1680                                     1.00917   3.6842E+05
  #      19   n1680                                     1.00934   3.6848E+05
  #      20   n1680                                     1.00958   3.6857E+05
  #      21   n1680                                     1.00929   3.6847E+05
  #      22   n1680                                     1.00945   3.6853E+05
  #      23   n1680                                     1.00930   3.6847E+05
  T o t a l s                                                     8.7618E+06
 Start time   12/26/2024 16:47:27
 End time     12/31/2024 00:15:13
 Elapsed time  372466 seconds for   12003 cycles using    24 MPP procs
             (    103 hours 27 minutes 46 seconds)
 N o r m a l    t e r m i n a t i o n                          12/31/24 00:15:13
